Page 1 of 1
Capture 11 October 2022
Posted: Thu Oct 13, 2022 2:08 pm
by G3ZJO
Captures of a small shower in the afternoon of 11th October 2022 between 13.18 UTC and 13.33 UTC (timing is not sync'd yet). SpectrumLab captures of events from just after 13.18 UTC are cut and pasted in sequence.
Location IO92ng 95Km from GB3MBA
111022 edit.jpg (322.71 KiB) Viewed 118551 times
Re: Capture 11 October 2022
Posted: Mon Oct 17, 2022 10:39 am
by johnberman
Hi
Good to see you getting captures, is it possible to increase the resolution in SL ?
Kind regards
Posted: Mon Oct 31, 2022 8:46 pm
by G3ZJO
Hi John
I am using the audio input to SL from a Yaesu Transceiver not an SDR.
I did a quick set up of SL to give the resolution I like. I see the scroll rate is 60 secs in a BW of 700 Hz in the capture posted, I also use 30 secs scroll. When time permits I will see what else is possible.
Regards
Eddie
Posted: Tue Nov 01, 2022 6:11 pm
by G3ZJO
The same event today with different SL set up. The first has better rsolution, the second may be better for observing precise timing.
Posted: Tue Nov 01, 2022 6:21 pm
by G3ZJO
The Captures in the last post were displayed in reverse order to that intended, the first is below the second with 15 sec time tics is above.
At the level of my expertise with SL this represents about the limit of the compromise possible.
